new the forum and first time boat builder
Ed Phillips
Re: new the forum and first time boat builder
Post by Ed Phillips »
Thanks again Matt and believe it or not I didn't even see that scale data. But with that said that scale equates to 1/32 = .250 which is exactly what my measurements indicated.
Thanks again Tom and since using both the posted scale and mine make the chine mathematically land at 8 1/2, as well as your recommendation I am going to push it up that 1 1/2" to meet the 8 1/2" landing.
thanks again guys
Ed
Ed Phillips
OK guys as noted previously I mounted the top of the chine at 8 1/2" from the top of the breasthook as calculated via scaled drawing. The transition is pretty smooth now with little to no fairing required. This should put what Tom calls the sweet spot at about 9 1/4" from the breasthook. I think I got it now?
Ed
Congrats Ed, looking good. Tom
Ed Phillips
Thanks Tom, I glued the chines this morning.
Ed Phillips
OK guys believe it or not I have the shear clamps on and am getting ready to do a bunch of fairing. I also made a cradle for it to sit in when it's right side up which I used to fit the shear clamps with because I was getting tired of crawling around on the floor. So I am getting ready to order my plywood which has brought up a couple of questions.
My Pee Wee calls for 3/16 or 1/4 on everything except the deck. I can get 1/4" but 3/16" appears to be somewhat elusive.
Is the 3/16" for the deck for reduced weight?
Is it for easier forming around the bends and bows?
Is there any reason why I wouldn't just use 1/4" on the deck?
After hours of reading both in this forum and others I have discarded the Mendards 1/4" plywood due to it's being structure plywood and not planking. I have however found another supplied that offers marine plywood in Okoume 1088, 5 ply $95.00 a sheet, Sapele A4 1 ribbon $74.00 a sheet, and Hydrotek 1088, 5 ply $57.00 (Red Meranti).
From what i have read the Hydrotek is heavier which I like because I like heavier boats, supposedly tougher in abrasive conditions, but I also read the Meranti splinters at the cut line but I would expect that has something to do with the coarseness of the cutting blade. I think I can get around that with a fine blade. Sapele from what I have read gives you a good cut but it doesn't carry the 1088 spec. Okoume obviously top of the line.
So if I go with the Hydrotek for the weight and advertised tougher exterior am I giving up bending or forming capabilities over the Okoume?
Should I just jump to the Okoume at twice the cost for this little boat?
1/4" will be fine for everything. I doubt you'll find 3/16". As far as the type, yes okoume is nicer to work with but I do think the Meranti looks nicer. Weight difference won't be a lot on a boat that size.
Okoume is more flexible than Meranti and I can't cut Maranti with it splintering so I would go with Okoume. Tom
Ed Phillips
Thanks Matt I will order all 1/4" and yes I agree the Meranti I seen in pictures did look real nice but given my grandson really likes blue I am pretty sure it's going to be painted anyway.
Thanks Tom with both you and Matt stating the Okoume is easier to work with I think I will go that route it's only 3 sheet for this little boat anyway.
Ed Phillips
Well the fairing is going pretty well especially considering this was a new word for me a couple months ago. So thinking ahead again as usual I have a couple questions. My instruction sheet calls out for the screws to be installed along the chine, shear, transom, stem, and battens.
No where does it state to install screws in the # 1 or #2 frame. So do I assume the attachment in these areas is bonding via the epoxy only?
BOM calls out for flat head screws which obviously have a countersunk design but I see nowhere to countersink the screw holes before installation. So do I countersink before installation or not because it's only 1/4" plywood and let them seat themselves?
Fiberglass or not is an option and not that I am against it but functionally is it for abrasion resistance? increased structural support like rebar in concrete?
Non fiberglassed areas calls out for resin type sealer followed by paint or marine varnish. So if I opt to skip the fiberglass is "resin type sealer" a thin form of paintable epoxy?
thanks
Ed
Ed
I regard to your message, I see your post here.
OK Ed,
I will render an opinion...
I used enough screws to hold the plywood bonded everything with epoxy. I put packing tape on one side of washers to keep the screws from countersinking. After the epoxy cured I removed the screws, drilled countersinks and reset the screws without washer.
I suspect the reason for not screwing along frames would be to avoid a perforation line perpendicular to the bend of the plywood, therefore, epoxy only.
The fiberglass adds very little structurally. Its value, to me, is in abrasion and punching resistance. Imagine dragging the boat up on a rocky beach and then stepping into the hull.
Most of us, not all, apply two or three coats of epoxy to seal/encapsulate the wood and then paint or varnish.
Ed Phillips
Thanks Tom that helps a lot. Makes sense not to weaken the stress point on the plywood by drilling holes in it and I should have thought of that, thanks for the explanation. I also like the idea of spreading the pressure outward via washers and countersink afterwards. OK but as usual I have more questions.
When you say you use enough screws to hold the plywood does that mean you don't put in all that is recommended in the design during this phase?
Once the epoxy is cured and you remove the washers and reinstall the screws do you install the quantity recommended and spaced as outlined like every 2" 3" and 4" ?
It sounds like adding the fiberglass is a good option. Just so I understand:
If I don't fiberglass do I used the epoxy glue I have for gluing joints to seal/encapsulate the wood?
If I do fiberglass does the glue that comes with the kit provide the sealing/encapsulating?
thanks again Tom
Ed
I marked where the screws would go and did a dry fit. I worked with screws and clamps to get a close fit, every mark got a screw in areas with a lot of bend, every other in the flat areas and clamps where I could because that's easier.
I don't know about kits. Suggest calling Gayle.
Ed Phillips
Thanks again Tom, I understand your procedure now and it make sense.
Ed Phillips
OK this is an update on my Pee Wee build. I have the sides on now and would like to share how I did it which may help someone. However, first off I have to state that I did it a little differently than the instructions and I used a butt joint at the stem rather than the suggested lap joint. Right or wrong my logic was since the bow was going to be subject to the most water pressure while moving I wanted the layers of the plywood buried and not exposed. So first off I laid a 4 X 8 sheet of plywood along the side of the frame with about 2" of overhang below the shear and clamped it in a couple places, and then I traced a line along the chine. Unclamped it and laid it on the bench and retraced the chine line about 2" above my first line giving me more room for adjustments (2" top and bottom"). Cut that piece out and them laid it on the other half of the plywood, traced it and cut it out so now I have both rough cut sides. Next pick a side and clamp it back on with the 2" overhang top and bottom. I made a pencil mark on the number 2 frame and a corresponding mark on the side plywood for alignment purposes. I then decided to pre-form the bend over the stem because even though the chine and the shear have a nice arc, the arc did not match the 12 degree angle on the stem exactly. So with multiple clamps and with wood blocks to space out the clamping force, as well as protect the plywood, rags and hot water I started the molding process. See pic #1. At first I put very little pressure on the clamps but after the first soaking of hot water the plywood started to bend very easily so I bent it about 1/2 way. Second soaking about 10 minutes after the first and the plywood was very moldable, so I clamped it right down tight to the stem. I let is sit overnight with the rags, then next day took the rags off and let it sit overnight again to dry in place. My guess is that it retained about 75 to 80% of the bend. Repeat the procedure for the other side and now you are ready to transfer the transition along the chine. I tried crayon with no luck, but chalk worked great for me and made a very nice sharp line. Cut the transition line with a saber saw and planed it flat so it was ready for pre-installation. This is where I put a screw in the chine up by my reference mark and screwed the plywood to then started to screw the plywood to the stem. As others have mentioned I skipped every other hole and I put flat washers on the screws to spread the load. I also put some wax on my screws for ease of removal and lesser chance of breakage. Once the plywood is screwed to the stem I simply snapped a line from the centerline of the stem, to the very tip of the breasthook, remember it's laminated so it's pretty easy to see the center. See pic #3 before cut, also note the transition along the chine is finished at this time as well as more screws are added for additional locating on final installation. I then simply took a crosscut hand saw and sawed off the excess material at the stem. Once that is done I repeated the procedure on the other side so in the end I had both sides pre-fit at the stem and the chine transition point. Now it was simply a matter of epoxy glue everything and remount the sides using the existing stem screw holes and the one location hole back on the chine. See pic #2 . Next saw and plane the plywood flush with the chine and you are ready to do the bottoms.
