Amigo Cronic Hairline crack
ButchSL
Post by ButchSL »
I have a hairline crack in the hull through the epoxy where the lead ballast meets the wood stem. I dug it out filled it with epoxy and it reappears. So my Amigo is on the hard and I am trying to fix this for good. Dig it out wide and cover with thick fiberglass wrapped from the starboard to port, screwed in, epoxied with G-Flex.
There is a very small leak in the bilge from this, about a cup a month when the boat is in the water for a while.
Don't how to send a picture from my computer.
Stan (Butch) Lapetz
ButchSL
Re: Amigo Cronic Hairline crack
Post by ButchSL »
will send pictures when I figure it out.
Stan (Butch) Lapetz
At the bottom of the "post a reply" is a tab "attachments". Go there and click the "add files" button and select the file.
That joint is a tough one, there is a huge stress load on the joint. I think there are only two types, those that crack, and those that haven't cracked yet. For what its worth, I would back the keel bolts off enough to open the joint, seal the wood with epoxy, coat the joint with 5200 and draw the joint back together. 5200 will forgive a little flex in the joint and keep the water out, epoxy/glass won't.
Return to “Sailboats”
