Glen-L 15 build
Re: Glen-L 15 build
Henk,
The inside edge can be used to support the sole.
HBlom
Re: Glen-L 15 build
Post by HBlom »
Made some good progress in the last day or two. Got 5 frame templates finished to my satisfaction. Used a combination of a track saw for the longer straight sections, a hand plane and a disc sander (for which I built a custom table) for shorter straight sections.
Also made some frame lumber decisions - going with quarter sawn white oak for the frames with mahogany plywood gussets. Finish both bright - should make for some nice contrast.
Fine tuning by hand
Fine tuning by hand
Custom built disc sanding table
5 done, quite a few to go!
Henk Blom
Mundelein, IL
HBlom
Re: Glen-L 15 build
Post by HBlom »
Progress update: I am down to touching up the last two templates for the frames on the Glen-L 15. They have turned out quite nicely, I think, but obviously the proof of that will come down the road a bit.
I am preparing for the next step, which will be to lay the templates out on 5/4 or 4/4 quarter sawn white oak boards, and was starting to think about how to line up the templates with the grain. What should I be looking out for? How critical is this? A couple of the deck beams are curved, and I'd love to find some boards that have a bit of that curve to them as far as the grain is concerned. But not sure how much time I should spend on looking for boards with that bend to them. I am pretty sure I don't need to get as particular as Acorn to Arabella or Tally-Ho, but I don't know for sure either. Open to input and feedback.
Cheers.
Henk Blom
Mundelein, IL
Re: Glen-L 15 build
If you are using white oak, the grain should be pretty straight. No need to over think it, just align the grain with the long axis of the parts and cut.
HBlom
Re: Glen-L 15 build
Post by HBlom »
Well, progress continues. Finished all the templates a week or 2 ago, and have been laying out the templates on the quarter sawn white oak. Spent a good part of today rough cutting them on the bandsaw, and them flush trimming them to the template on the router table. Works very well. Got the oak for frames 1 and 2 done now. They are coming out about 1/4" smaller than what I laid out on the plywood, which I think is mostly due to the the templates being finished to the inside of the black lines on the plans. I can't imagine that will make a huge difference on the final product.
I have more pieces rough cut, so more to come in the next couple of weeks. I will probably have to take a break for the winter, since epoxy does not do well in Chicago winters, and my garage is only heated with a kerosene heater when I am in it!
Henk Blom
Mundelein, IL
Return to “Sailboats”
