Substitute "AC" Douglas Fir Plywood for "AB" Ext 3/4" ?
jkwatson
Post by jkwatson »
I am unable to source "AB" grade Douglas Fir plywood in the Houston area. I can locate "AC" grade which I am told is finished one side vs two sides. The "AB" is in the Glen-L Bill of Materials for seat brackets, floorboards and seats, transom, stem, etc. Does anyone see an issue using the "AC" grade?
Thanks!
Re: Substitute "AC" Douglas Fir Plywood for "AB" Ext 3/4" ?
Try Houston Hardwoods. I get my Marine grade plywood there and there are sure to have the other types you are looking for.
If you can I would suggest making the transom and stem out of as high of quality as you can find. The seats and floorboards etc. should be fine with AC though.
jkwatson
Post by jkwatson »
Matt - thanks for the info. I did just find AB Douglas Fir 3/4" at the Plywood Company of Fort Worth, so will be making a trip to pick some up!
Jack
drm_wfd
Post by drm_wfd »
Wood World in Dallas,TX has all kinds of marine grade plywood. It may be closer than Houston for you. See the web site for details: woodworldtx.com
Wood World of Texas LLC
13650 T I Blvd Ste 101
Dallas, TX 75243
972-669-9130
Woodworldtx@gmail.com
Don
Weatherford, TX
Bring your wallet at Wood World, they are very proud of everything.
Return to “Wood and Plywood”
