QUESTION ABOUT SCARFING JOINT IN MOTOR STRINGERS
Shawn K
Post by Shawn K »
Today I picked up the mahogany I needed to start building my frames, I was able to find a place local to me that actually had African Mahogany but a limited amount, and sizes. I was also trying to resolve the issue of finding the wood for my motor stringers. I seem to be having problems finding 2 x4 mahogany that is in a length I need for the stringers, which is 15'. the longest I have found was 8'. Now I know I can probably scarf joint them but I certainly have concerns about doing this, being the joint would be right in the middle of the stringer and probably at the point with a lot of weight and stress on it. Can anybody chime in and give me some advice and input on this subject and the best resolution for me? I did read in Robertas" tornado build where She used white oak and wrapped it with sapelle,or I could probably do the same with Douglass fir, but id really like to keep it 100% mahogany. THANKS`AND PEACE
Re: QUESTION ABOUT SCARFING JOINT IN MOTOR STRINGERS
Shawn, Use two 1 x's and scarf and laminate. Tom
My motor stringers are 5/4 x 6" white oak sandwiched between 6mm Okoume plywood. The white oak part of the stringers is full length and not scarfed and are a full 6". Stringer extensions are added, but they are offset per plans for the forward frames and are 4/4 x 4". The plywood is beveled and butt joined using ring shank nails, screws, and epoxy to laminate the stringers.
The way I made them is extremely strong and stable. I would rather choose another species of wood than scarf stringers. Laminating and offsetting joints would be better.
Return to “Wood and Plywood”
