Okume 1088 vs Meranti 1088
Re: Okume 1088 vs Meranti 1088
Baron
I've seen birch plywood for cabinet work. I don't know if it was Baltic. It was good looking material. I don't know about the glue.
matt167
Post by matt167 »
The birch that I know of has only interior glue. Most high end lumber yards and box stores carry it. If you are just looking for cheap stuff you can get easily. Doug Fir ABX is available down to 1/4" in most manufactures. This is the type of thing that a good lumber yard will special order for you.
There are also exotic type underlayments that are available which could be acceptable but they are only available in 1/4" and 3/8"
OKIBOY
Post by OKIBOY »
Thanks to all posters this information is very helpful. mrintense your build is inspiring. I have recently retired and moved to coastal NC. I have taken on building a plywood over frame 18 ft skiff. Kindest regards.
Bill Edmundson wrote:
Tue Feb 11, 2020 10:56 pm
Baron
Bill,
I tried some of that nice looking 1/4” Birch plywood, it’s crap. Your suspicion about the glue was right on, I could peel off the birch layer with my finger nail. Threw most of out. Marine grade plywood only, it’s worth the cost every time !
Return to “Wood and Plywood”
