cover boards
pamelalynne1
cover boards
Post by pamelalynne1 »
What is the recommended thickness for cover boards over a plywood deck?
Re: cover boards
Depends on if you are expecting them to add strength over the plywood alone or not.
On my Squirt, they are 3/16" over1/4" plywood.
Re: cover boards
On my Torpedo, I planed my deck and cover boards to just under 3/8". This was over 1/4" plywood. Some builders like to emulate the old Chris Craft boats with the really thick cover boards that have a big radius to the sides. This needs some pre planning during the build.
Re: cover boards
What boat design are we talking about?
For me, 3/8” thick works well over 1/4” plywood sub deck because it’s a good use of material. 4/4 stock re-sawn and run through planner yields about 3/8”.
3/8” leaves me enough material to sand out any low spots in the deck. Structurally there is no need for more than 1/2” total thickness if deck battens are built to the plans.
Return to “Wood and Plywood”
