Help needed !
Nigeb22
Help needed !
Post by Nigeb22 »
Hello all,
I am building a barrelback in Portugal and just starting off feeling my way through the plans
which takes time.
I have been cutting out the bow section 3x lengths of 18mm plywood and the inside has a curve
which now needs to be trimmed back to the line
On the outside its a concave curve and I have a flat wood plane..?
on the side it convex and I don't have anything to trim this
Ok I not know much about this but that's why there's a forum
Can anyone please tell me how to trim this back to a nice curve please
cheers
Nige
bow section
bow section
Re: Help needed !
Inside curves can be sanded to shape using spindle sanders or sanding drums. Drums can be mounted on drill presses.
Re: Help needed !
I use a hand belt sander with very course grit belt to shape parts.
TAB
Re: Help needed !
Post by TAB »
Roberta wrote:
Fri Dec 04, 2020 8:51 am
You can even wrap sand paper around a large wood dowel ( 25 mm +)and use that manually. It takes some effort, but it does work.
parsj1957
Re: Help needed !
Post by parsj1957 »
Also if you like hand tools - a spoke shave works well on both inside and outside curves --
J.
Nigeb22
Re: Help needed !
Post by Nigeb22 »
Thank you everyone I have a belt saner and ordered up a spoke shave as
I see there are lots of curves to shape so I need to get good at this
Anyway thank you its great fun to be building a boat again!
Nigeb22
Re: Help needed again
Post by Nigeb22 »
Hello all
I can see I'm going to be a regular on here to make sense of the plans
I managed to create lot of dust today fairing down the Stem to nice curves and size
and I came to cut out the Breasthook when I got stuck
The plan section seems ok.... 2x 18mm( ¾ ins) marine plywood with a notch to locate into the back of the stem
which allows for a 40mm longitudinal to slot in front and then the stem faired down to a point and flush with the longitudinal
Ok so far so good the confusion arises with the vertical section which indeed seems to show 2 x 18mm ply but one covers the top
of the stem the other slots in underneath and behind but neither seem to do what the plan shows...?
Can anyone tell me what/which drawing is the correct one to follow and explain when its mounted upside down in the frame
does the breasthook fit flush with the lowest part of the stem ( when viewed upside down) and so this is the level the plans demand
as measured from the datum line and then I build up and support the stem at this level?
I hope I've explained this ok
As ever your wisdom is appreciated
Nige
Boycies Barrelback in Portugal
Re: Help needed !
You make the bottom one notched per the dotted lines and the top one following the outside lines to form the tip that will extend over the stem.
Nigeb22
Re: Help needed !
Post by Nigeb22 »
Thank you for your prompt reply and info
I think I understand so we have the exact shape of the bottom one which is notched into the stem
Whats the shape of the top one why doesn't the plan explain this ?
I may be feeling my way on this but that is not explained on the plans at all well
I shall pass on my comments to Gayle, are the plans drawn to assume a level of knowledge?
kind regards
Nige
Re: Help needed !
The top piece is drawn over the bottom and overhangs the stem. The angled tip is the approximate shape of the leading edge of the stem.
If you don't already have it, get the "Boatbuilding with Plywood" book from Glen L. It will help explain many things about boat building.
Re: Help needed !
Post by DrBryanJ »
Both the top and bottom are cut to the same size, only the bottom piece will have the notch. The sides are angled. I know with the Malahini the angle is specified. I don't know if it is with the barrelback. I made my two pieces, attached them together and cut the angle with a table saw. Watch where you put the screws or nails. Too close to the edge and the saw will hit them.
Feex
Re: Help needed !
Post by Feex »
DrBryanJ wrote:
Sun Dec 06, 2020 9:50 am
It's actually a very soft curve, not a straight angled cut. Trace the pattern and cut with jig or band saw.
Return to “Wood and Plywood”
