Epoxy is not curing - a sticky mess
thudpucker
Re: Epoxy is not curing - a sticky mess
Post by thudpucker »
What I had trouble with, was getting all the 'stuff' out of the mixing container. I was never sure I had the mix correct because so much of Part A and Part B was left in the little paper cups.
upspirate
Post by upspirate »
I'd give it a week to see what happens.
I did most of my building last summer in 95 degree F heat,when I did some in 45-50 degree in the late fall-winter, I couldn't believe the working time I had and how long it took to kick off!!! :shock:
And I mix by volume some 1/1,some 2/1, some 3/1, and some 5/1 depending on which product I'm using.
so far, no bad batches....I don't use pumps,I measure into containers
len sandok
Post by len sandok »
:) After waiting for about two weeks I still had a few areas that were sticky. I decided that I had to do something rather than just wait. I soaked a rag in vinegar and used a little elbow greas on those areas. Then I wiped again with a clean dry rag and the mess is gone. I still do not know if it was caused because I used the wrong proportions of hardened to epoxy or because the temperature went below feezing right after application. I thought the vinegar tip wa worth sharing. I read it somewhere on this site, but I don't remember who told me about it. Thanks - whoever you are - you saved me a lot of time and money.
Bob Perkins
Post by Bob Perkins »
I'll bet $10 it was a bad mix and not temperature drop.
Once it warmed up - it should have started to cure.
Regards,
Bob Perkins
All the Fun Stuff
upspirate
Post by upspirate »
Yea!!!
Might not be a bad idea to do a test batch.
Onward and upward! :D
len sandok
Thanks, I've done a few more batches since the "sticky mess" and they seem fine. I am going to assume it was my mistake. Thanks for all of your help!
JWSAV
Post by JWSAV »
1 problem that really stands out and is very important when mixing the parts together. VERY IMPORTANT.
When you add part A and B to a mixing cup/bowl, some of the product is on the sides of the container and doesn't get mixed in. When you use the product, any of this that ends up being used will stay stick/gummy and never cure all the way especially when using the thicker stuff.
How to keep this from happening.
Even though this may be a pain, you have to do it.
1- Mix parts together in a container.
2- Pour the mix into another container
3- Then, mix the pre-mixed stuff again in the new container. This keeps any of the unmixed stuff from the sides and/or bottom from contaminating your batch.
Works EVERYTIME.
Of course, proper temps are important also. I get a Warmer bulb and use it in a clip on light fixture. It's a heat lamp. They come in amber or clear. Looks like a flood bulb kinda. If it's cool out leave the light on the pieces for 15-20 minutes and then cut it off until you finish using your mix. Then turn it back on. Remember not to have it too close to your work. 12-20" away should work ok.
Good Luck!
Mark-NJ
Post by Mark-NJ »
This is a 6 year old thread! The original poster, to whom you're wishing "good luck", hasn't even logged into this forum since Nov 2014!
msohrt
Post by msohrt »
To anyone that has experienced this issue don't panic. And don't try to scrape or sand off this gooey mess. Get some rags and a can of acetone and wet the rag well. Wipe down the piece that you are working on and then let it dry for about 10 minutes. Now you are ready to mix up a new batch correctly and reapply. I had this happen to me and this is how I was able to recover from my mess. The new batch cured just fine. :D :D :D
Return to “Epoxy”
