epoxy coat looks milky - advice?
bobinpowayca
Post by bobinpowayca » Tue Jan 17, 2017 11:37 am
Hi, I'm building Geronimo - I just finished fiberglassing the deck - okoume, 2 coats of silver tip epoxy resin, glass, then 2 or 3 fill coats of resin. I'm building it outside under a canopy, usually cover it also. Up to now all of the resin coats have been fine - dried hard and glossy. I put on the final coat of resin yesterday - next I will prime it with 2-part epoxy primekote.
Here-s the problem. I rolled on the last resin coat early yesterday afternoon. By evening the resin looked great - shiny, but still a little tacky so I left the cover off (still under the canopy though). Well, this morning the resin has turned milky white - kind of chalky, you can scratch it with your fingernail but it still real milky looking. Overnight it got down to the upper 40's and this morning there was a nice coating of dew all over the resin.
Do you think the resin is basically okay? Silver tip is non blushing. Thinking I should wait a few days then sand it prior to the epoxy primer. Any thoughts? It has dried hard but is pretty white. Thanks for any advice. Bob
_______________
PBR support (1968)
Re: epoxy coat looks milky - advice?
Post by Bill Edmundson » Tue Jan 17, 2017 2:51 pm
It's definitely the moisture. Let it sit in the sun if you can. Try hitting an area with a blow drier and see if it clears or at least hardens. I'm pretty sure it will harden.
bobinpowayca
Post by bobinpowayca » Wed Jan 18, 2017 2:13 pm
Thanks Bill. I sanded it all down last evening with 80 grit paper on my rubber block, the white coat's thinner - you can still easily scratch the white with your fingernail, so today I sanded it again with 80 grit, then went over it with 120 grit on my orbital - still whitish but harder to scratch. I think that'll do it. Now to cover it up real good before the storm hits tonight. :D Bob
_______________
PBR support (1968)
