Mas epoxy temps
jamo
Mas epoxy temps
Post by jamo »
What's the lowest temperature that Mas epoxy will set?
Re: Mas epoxy temps
Jamo
I usually use brushes when I epoxy. I fold my glove back over the brush. Then I put it in the freezer. I can use it again the next day. After three days, it has cured like a rock in the freezer. Doesn't matter the brand.
Re: Mas epoxy temps
I’m in agreement with Bill, just takes longer. My technique for cool temp epoxy application is keep the epoxy warm, (don’t over do it) mix it in a warm room and let it start to kick off. Then head out to the cold shop to apply it.
Re: Mas epoxy temps
I don’t know where you live and Cold is relative, I live in Texas so my technique may not work in your cold.
galamb
Re: Mas epoxy temps
Post by galamb »
I have never used MAS but do use East and West System - live in Canada.
With the fastest hardener available I can generally get it to cure as low as about 10C/50F.
The temp can drop below that overnight (a bit) and it still cures but I look for a good three or four hours at (that temp) to allow it to kick off.
If it's under 10C/50F I won't epoxy. Trying to remove unset epoxy is worse than a pain :)
Graham
Return to “Epoxy”
