Epoxy and UV
Ga-Steve
Epoxy and UV
Post by Ga-Steve »
How long does it take for UV rays to undermine epoxy? Last fall I was able to get the glass and a layer of epoxy on my hull before the cold temps caused a standstill. My plan is to put a couple of more coats of epoxy on before painting. Just curious as I have heard epoxy needs a UV barrier. Thanks, Steve
Re: Epoxy and UV
Post by JimmY »
Yes, epoxy needs UV protection. Is your hull outside in the sun? If not, there is no concern the epoxy should be fine indefinitely if not exposed to UV directly.
Ga-Steve
Re: Epoxy and UV
Post by Ga-Steve »
In the morning, sun hits it until around 11. It is covered by an awning but morning sun does shine on it.
There won’t be any issues putting on a couple more coats before painting??? And thanks, Steve
Re: Epoxy and UV
Post by TomB »
Steve,
The Gougeon Brothers say that 200 hours of direct exposure to sunlight can be enough to cause epoxy to start breaking down - so put a tarp over it if it's going to sit out naked in the sun for a while.
Re: Epoxy and UV
You should start to see a visual difference if it is starting to affect the epoxy. You can always sand it down a little and put another coat or two on.
Return to “Epoxy”
