Radiused Corners for Fiberglassing - Help and Advice Needed
btucker
Post by btucker »
I'm a first time boat builder and am ready to fiberglass the hull of my squirt. Or at least I thought I was ready! Then I read in "How to Fiberglass Boats" that I need to radius the crisp edges prior to fiberglassing the boat. Do I need to radius the chine, transom and stem? How difficult is it to create a crisp edge on the transom during the fiberglassing process? Thanks.
billy c
Re: Radiused Corners for Fiberglassing - Help and Advice Nee
Post by billy c »
glad you have the book to help out! very easy to bring back the edges after glassing. can mix a thickened batch of epoxy and build right back up. making a "dam" of tape works well on vertical areas to help epoxy stay put while setting up.
btucker
Post by btucker »
Thanks for the advice. I guess I have a little more work to do before I start with the fiberglass.
Return to “Fiberglass”
