Getting a smooth finish after the Fibreglass
stephenburnett
Post by stephenburnett »
I am wondering if anyone has used a product called "Slicksand" after the fibreglass cloth has been applied?
The finish after two coats of FG and paint is unsatisfactory and Slicksand was recommended by a Fibreglass specialist - because I had already painted the FG and Gelcoat would not take. Any experience using Slick's sand out there?
Re: Getting a smooth finish after the Fibreglass
I would sand back to the FG resin, recoat with at least one more coat of resin, then use a high build primer prior to top coating. Sanding and prep is key to that high gloss finish. Don't expect gobs of paint and primer to cover up a poorly prepared surface.
stephenburnett
Thanks Roberta - are you suggesting that I sand completely through two layers of fibre glass cloth to the plywood?
Put 2 or 3 three coats of epoxy resin on top of the fiberglass. Not more cloth. Then you can sand it smooth without removing the cloth. If you get into the cloth you will see it. Just add a layer of resin and finish smooth. You will still need to coat with paint or clearcoat for UV protection.
Like Bill suggests, just sand down to the cloth, but not to the wood. Add resin to keep the cloth covered. Once you have it all smooth and coated with resin, start your primer and top coats.
Mr Hot Rod
Post by Mr Hot Rod »
The West System manuals manuals are a must-read if you are doing anything in fiberglass. Pay attention to the number of barrier coats to guarantee a pro outcome. If you are restoring a fiberglass boat, this is a good place to start (or impress your friends with your glass knowledge !) ____________________
Click Image to see video.
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
Glen-L Hot Rod build thread
Glen-L Boat Video Directory
Forum Support Knowledge Base
Return to “Fiberglass”
