Converting an outboard engine to an inboard
Re: Converting an outboard engine to an inboard
I converted my inboard 3.0L from a I/O. all that midsection/lower unit/steering crap is heavier than you think. I weighed that crap, and I weighed the strut/rudder/shaft/Velvetdrive also. I was shocked what I found out.
Brian
Post by Brian »
Not sure I follow. You mean you removed the inboard and made a transom for an outboard on the stern? Not really what I have in mind.
No, the other way around.
I bought a donor I/O boat, removed the engine, sold off all the I/O stuff, and made myself a straight inboard.
TAB
Post by TAB »
Some of the 1st generation small jet boats used a power head from an out board. The impeller was run vertical.
Brian
Post by Brian »
I guess my most significant worry is thrust under the center (CG) of the hull. What's wrong with having the thrust that far forward, as opposed to at the stern?
jenko
Post by jenko »
nose dive
Brian
Post by Brian »
Modern outboards have power trim. How would you get nose dive?
Return to “Boat Power”
