Pee hole
verniam
Pee hole
Post by verniam »
Mud daubers pluged the pee hole on my new never run Honda 60. I've cleaned the mud out but still don't get water when run with muffs on the hard. I suppose there must be a pupae in the line but how do I get it out without disassembling the motor. The line appears to be hard to get to. I have removed the outer orifice to no avail.
Re: Pee hole
Post by billy c »
The flush port on the motor may give you a little more water pressure than the muffs. Should not start the engine though using that as a cooling source
Re: Pee hole
They deposit way up in there. They left me a gift in the breather tube on a generator. I had to disconnect the other end of the hose, blew air, then a solvent drip and more air which did the trick. Getting the hose back on was a PITA! Tom
verniam
Re: Pee hole
Post by verniam »
I fixed the problem by dismantling the port side of the upper housing which allowed me access to the hose connected to the pee hole. I removed the approx. 12" inch hose and ran a wire through it. Quite a pita but now it works. Now I put a piece of masking tape over the hole when not using the motors.
Re: Pee hole
Post by DrBryanJ »
Now you need one of these
Return to “Boat Power”
