Pee wee build in Sydney
chugalug
Re: Pee wee build in Sydney
Post by chugalug »
:D you'll have to cut notches into frames for that piece too.the frames toward the bow will have to be angled somewhat so piece or pieces can be bent around.On my Bo,I laminated thinner pieces around so as to ease bending.didn't worry about fairing until boat was ready for ply.
chubs
Post by chubs »
Here I'm glueing the transom end of the chine firstly:
chubs
Post by chubs »
Afterwards I figured it'd be easier to pre-bend the other chine before installing it:
chubs
Post by chubs »
Bending the half installed chine with hot water seems to help a bit:
chubs
Post by chubs »
Finished the chine on the other side too now. Used a bit of offcut to fill in the acute gap behind it nicely. What next?
chugalug
Post by chugalug »
Is that stem square across? or faired to match with the glued on pieces? center of layered stem should be pointy so ply can attach to it as well as chine and shear.
chubs
Post by chubs »
Stem is square. You have a point. Bummer.
chugalug
Post by chugalug »
Maybe since the boat is a small one,you could epoxy in a small triangle piece on the stem or are you going to cut loose the glued on pieces and relocate further back so you can fair stem? :roll:
polarisman14
Post by polarisman14 »
Yeah the best way to do that would have been scribing a line in the stem for where you want the chine to fall, an inch or two back from the square shoulder of it, and attach there. That way there is enough material to make the contour of the stem match where the chine is landing.
hzchevy
Post by hzchevy »
Getting there chubs. No big problem with the stem. I'd just get an angle grinder with a thin blade and cut the chine off and relocate. I'm pretty sure I faired my stem first before I attached the chine to it. It seem to work for me.
chubs
Post by chubs »
What do you use to fair the stem? A power plane?
chugalug
Post by chugalug »
That's what I used on my bo-jest.that and large angle grinder with coarse grit wheel. :D
jenko
Post by jenko »
I used a spoke shave
hzchevy
Post by hzchevy »
I also used an angle grinder with a corse grit wheel.
chubs
Post by chubs »
Photo from before our conversation about fairing the stem: took it outside and flipped it to get the sheer on.
