Off Center Engine Hatch, thoughts?
Poll ended at Tue Jun 04, 2019 6:59 pm
1. Leave the planks the same width and have an extra stripe on the starboard side (stripes will line up but the engine hatch will be skewed)
1
11%
2. Center the planks on the engine hatch, as is, to get even stripes across the hatch and bulkhead (Scale as necessary) and don't worry about them not matching up with the bow stripes (At least the hatch and bulkhead will be symmetrical)
3
33%
3. Cut out one side of the bulkhead to center it up (seems like a lot of work...) and make a the engine hatch a little bit wider.
5
56%
Total votes: 9
Milhouse
Post by Milhouse » Sat May 25, 2019 6:59 pm
I have been putting this one off for awhile as I am a bit stumped.
I am looking for opinions on what to do about my Off-Center Engine Hatch. Its only off by about 3/8" but the issue is that if I keep the deck planks the same width that they are on the bow then there is an extra stripe on the starboard side on the "bulkhead" (I'm not sure what you call it, the divider from Cockpit to rear or boat). When I installed the bow planks the foredeck was not quite symmetrical so the port planks are a bit wider which is exacerbating the issue to yield this extra seam on the starboard side.
I was planning on planking the engine hatch (when I make a new one) to match the bow with a king plank etc. Since its not centered it will have the same issue with the stripes skewed to one side.
The transom (which is narrower) has all the planks scaled so there are the same number of planks & seams as the bow.
Options:
1. Leave the planks the same width and have an extra stripe on the starboard side (stripes will line up).
The perspective of the pictures makes the widths look sorta wacky...
16' Ski Boat Restoration
17' Overnighter Sloop
Rich Coey
Re: Off Center Engine Hatch, thoughts?
Post by Rich Coey » Sat May 25, 2019 7:39 pm
I vote for #2, unless you stand at the end and sight down the lines you will never see it. it will look fine.
Rich
Post by kens » Sun May 26, 2019 6:05 am
plank to match
you can even lay that right odd plank such that it covers the hatch & bulkhead together, then later cut out the opening for hatch to open.
that way all the grain color, grain pattern, grain lines, all line up
Post by TomB » Sun May 26, 2019 6:25 am
One more option...
Add a layer of ply to one side of the engine cover so the top becomes symmetric and then redo the hatch-band so that it is symmetric too hiding the asymmetry underneath.
Post by Roberta » Sun May 26, 2019 7:29 am
Symmetry is key in a boat's aesthetic appearance.
Post by mrintense » Sun May 26, 2019 8:35 am
One more option...
This seems like a good option to me.
Carl's Vera Cruise Build
Milhouse
Post by Milhouse » Sun May 26, 2019 12:39 pm
Thanks for the advice so far. I took some more pics today so you can see what might be involved.
Tom I think this is another way of saying option 3 because I would need to cut the starboard bulkhead to make the hatch wider.
Measuring from the center line:
The starboard side hatch opening starts at 14 7/8"
The port side hatch opening starts at 15 1/4"
Delta of 3/8"
Post by TomB » Sun May 26, 2019 1:36 pm
Jim,
I was imagining adding 3/8 to the side of the engine house. Seeing the photo, it would be notched so as not to go between the bulkheads but would require new cover strips. Not sure how the house is attached, if hinged - never mind.
Post by TomB » Sun May 26, 2019 1:47 pm
Jim,
Just took another look at your restoration thread. As another option, could you subtract 3/8 from one side of the cover, ie, move the side wall in 3/8 and add a cheek piece between the bulkheads to keep it tight?
