MI Malahini Build, Post Flip.
footer
Re: MI Malahini Build, Post Flip.
Post by footer »
I forgot that I did get my bow eye/lifting eye finished. I made it out of stainless and polished it.
Bow eye / lifting eye.
Sarnian
Post by Sarnian »
Hey there footer - I'm guessing this has involved some welding - TIG? Any details?
Biss
Post by Biss »
Nice metalworking!
footer
Post by footer »
Thanks. Yes, I made it in 5 pieces. Two 3/16" halves on top, two 1/8" in front, and the solid 1/2" rod I heated and bent. Screwed down with stainless screws and one big 1/2"x4" lag bolt.
My tig and plasma torch (Harbor Freight)
Post by PeterG »
Excellent metalwork to go with the excellent woodwork :D
footer
Post by footer »
These are two abrasive wheels that were a life saver for working with stainless. The Blending wheel (Right) I purchased at Airgas (welding supply house) for $12. It's similar to a grinding wheel, but less abrasive and very easy to control and contour welds and edges.
The Rapid Blend (Left) is a smoothing wheel and takes out the scratches the Blending wheel leaves (although it can leave very fine scratches). I bought it at Alro Steel (metal supply house) for (obviously) $23.
Both wheels were instrumental in working with the stainless.
From there I used a polishing wheel with a stainless polish on my bench grinder to get the shiny finish.
Stainless abrasive and polishing wheels. Left: takes out light scratches leaves a smooth surface for fine polishing. Right: Abrasive wheel for smoothing and contouring welds and rounding edges, but will leave small scratches.
Sarnian
Post by Sarnian »
Footer thanks so much for the information - I really appreciate it. I have been playing around with a cheap MIG and using flux core 308 SS - trying to weld 18ga 308. It has been horrible - a combination of lack of knowledge, wrong tools (perhaps), and no skill :?
Your finished product looks great.
footer
Post by footer »
Yeah, flux core spatters as much metal as it puts down. Really hard to weld thin stuff with it without burning holes in it. If you can get solid wire and run argon, you will have much better luck with it.
I think I paid $1,500 for this tig a couple years ago, and if you look back a page, I welded my 18 Gage flat L-bracket with it. Very easy to control the heat. My eyes aren't so good anymore and my hand not so steady, but it's still easy to control. It will also weld aluminum and stick weld.
Mind you, I'm not a pro, just my experience over the years.
By the way, Youtube has many great videos on welding. Justin, on "The Fabrication Series", is an outstanding instructor.
Sarnian
Post by Sarnian »
yes...I'm torn - I want a cutwater etc...and it would probably be cheaper to have someone make them - but I enjoy learning this stuff. At the moment I'm trying to find a cheap way to get hold of some shielding gas, then I was going to try upping to 16ga 308, welding with solid wire, and see how that works out. Who knows, it it works I might start to go welding crazy - there'll be stainless steel adornments everywhere. The boat will end up weighing a couple of thousand pounds.
Your build is looking fantastic...thanks for sharing all the photos.
footer
Post by footer »
So, what little time I have gotten in working on my boat, has been spent working on this windshield. Quite time consuming. I'm checking into having my parts professionally polished as it takes a lot of time to polish with the equipment I have. Depends on what it will cost.
Roughing in windshield
polishing stainless side plates.
BarnacleMike
Post by BarnacleMike »
The time you're putting in to the windshield is really paying off. That looks great!
Biss
Post by Biss »
I agree, Metalworking is looking great!
Looks pretty shiny already. I really like that windshield.
Milhouse
Post by Milhouse »
I dig the windshield! I had not considered fabricating mine; but I just may now, thanks for the inspiration! I have been looking for more stuff to tig now that I have gotten into it (also have a HF Tig :D )
16' Ski Boat Restoration
17' Overnighter Sloop
footer
Post by footer »
Thanks guys. I priced having these three pieces polished and it'll cost $300-350 to a mirror finish. Guess I'll have to do it myself. Won't look quite so purdy, but it's in my tax bracket. lol
I've been watching youtube stainless polishing videos.
