starter issue
jamundsen
starter issue
Post by jamundsen »
Installed my battery last night with hopes of turning the engine over. Didnt work as I had the wire attached to the wrong terminal on starter. There were two terminals so I had a 50/50 chance. 45 minutes later the big moment arrives as I turn the key and the starter turns over great. Just not the motor. As thoughts of having to remove the motor go thru my head I discovered that the starter does not extend into the bellhousing far enough to engage the flywheel. After hours of research on the internet i found that I have the wrong starter so new one is one the way and the big moment of turning the engine over has to wait some more.
John Amundsen
Monte Carlo
Lakeland,Fl
Re: starter issue
John
I had starter issues, also. When they tested the engine they stripped the terminal post. Lots of frustation for sure
jcallends
Re: starter issue
Post by jcallends »
All in a boat builders day, John, keep us posted on this, JC.
Return to “Electric Power”
