Inboard Direct Drive Rough Parts List?
CodyP
Post by CodyP »
I know that every engine is different...
But is there anywhere you guys know of where I can find a "Rough" parts list for everything needed for a direct drive motor?
Cody P.
The dream will never become true unless you fabricate it yourself.
fergal butler
Re: Inboard Direct Drive Rough Parts List?
Post by fergal butler »
The basic bits you will need are
1) shaft to engine coupling
2) stuffing box
3) shaft log
4) strut
5) prop shaft
If you haven't already get the "inboard motor installations" book, it explains every thing you will need and how to set it up.
Mr Hot Rod
Post by Mr Hot Rod »
You didn't specify whether you wanted a transmission or not, so I posted links for both.
Conversion & underwater hardware for a small block Chevy - no transmission
Conversion & underwater hardware for a small block Chevy with transmission
Inboard Hardware Catalog
Inboard Motor Installations by Glen L. Witt & Ken Hankinson
Hope this helps !
____________________
Paul Kane
Kane Custom Boats Ltd.
Chelsea, Quebec
thudpucker
Post by thudpucker »
Dont forget the Riser at the end of the Manifold. It doesn't show in the photos but it's necessary! 8)
v-driver
Post by v-driver »
Risers? We don't need no stinkin' Risers!! :lol:
All in fun, Thud my friend!
Paul Miller in Memphis, TN
"Yeah, I had lunch with him last week at the Cracker Barrel out on I-40."
thudpucker
Certainly not a Stinking riser :lol:
Back when I worked on boats in the Puget Sound area, there were a number of cabin boats with the Engine inside the cabin, the Riser exposed to provide heat for Cooking.
I'll bet some of those Risers were "Stinkin risers" :wink:
CodyP
Post by CodyP »
question guys:
Engines are my weakness: I have never done the Direct Drive thing...Always been an Inboard Ourboard guy, the I.O. has the transmission in it....
I thought with Direct Drives you had to have a transmission??? I saw in the post above set ups for or without a transmission????
OH BOY....
v-driver
Post by v-driver »
Cody,
My V-drive has in-n-out, but I can't put it into gear with the motor running. In that sense, it's like a direct drive. Put it in gear, point it and fire it up. A paddle helps with this...
I coast to a stop and simply idle to the point that I kill the motor and drift to the dock.
Simplicity at its best.
Paul
