The transom images are just the last few feet of a boat- just boxes with engine mounts- the discussion is only about that area of the boat so the images/sketches only show that much "boat".
On the metal design thread we've gotten into some discussion of the ways to remodel stock hulls. That reminded me of one of my permanent smiles in welded boat building. How to design the 'best' stern arrangement for the outboard engine?
The stern of an outboard powered welded metal boat can be arranged in different ways and since we all have different ideas about the right way things should be…. Well, we could, each of us, prefer one or another of those arrangements.
I’ve built lots of welded metal skiffs and so I’ve been involved with many people going around this decision cycle to decide which stern they like best? In fact I’ll be trying to show how we got here? (current design summary) What lead to the changes, and what thinking I’ve seen and what thoughts I’ve had on the subject.
I’ll start with a little stroll down memory lane and remind us all why things all started on the transom of the skiff? To tell the truth the real start was inside the boat, the outboard engine well, forward the transom needs a brief mention as well. In each stage, I’ll try to remind us of the thinking the justifies that stage or design arrangement and to suggest what lead on to the next design evolution.
Please feel free to explain what I miss, to remark about your location and the experiences there, and to suggest other facets that I will naturally miss.
Disclaimer: I don’t intend to find fault with your opinion, I don’t intend to suggest that as a builder I’m any way qualified to suggest my ideas are better than yours. On the other hand I will probably poke fun at the logic and reasoning I’ve learned from others’ as they’ve explored this topic. These stern arrangements could be used on any given welded aluminum planing boat so they do qualify as potential design modifications to stock plans.
Let’s begin with outboards: they started out smallish. The 100hp, or as we now know 300hp engines were lifetimes away when the initial small horse outboards first appeared. So originally outboard engines were light weight, not huge in size (compared to the original inboards) and reasonably compact. But they were also engines that needed tending. Where to put them? On the transom; (I'm not mentioning the obvious fact these initial small engines were designed to go in this location); in side a well?, in the bow inside a well? hanging off the bow?
So where did all this begin? Here, is a pretty little wooden row boat made to move with oars or maybe a sail?
Now we're getting somewhere, the boat while very nice looking is still not made of metal except for the very new (we're talking history here not the model year of the kicker) power. No longer pulled or pushed by oars, and quite a bit bigger because of the ability of the new "engine on the transom" propulsion, the skiff is deeper, wider, longer and moves incredibly faster than any human can row the previous little boat.
But the short shaft made the mount a cut down on the transom so potentially a weak link in the gunwale for shipping a follow sea? Swamping and perhaps causing the loss of the skiff if it were loaded and didn't float?
What's next? (beside bringing in metal boats) Wait; forgot to mention the reasons to stern arrangements and here is where the history gets tangled. But first a word about outboard wells.
This little boat has the engine's transom inside the actual topsides and overall aft most transom- an outboard well. There are reasons for this arrangement, slow boats that don't plane, flotation aft the engine lifting the stern in a following sea, access to the early engines, and modern ones too if the skipper (as here) is inexperienced, and if you're fishing the wheel is below the bottom inside the bottom and out of the way of gear. All these reasons lead early builders, often building for commercial fishermen, to install wells. Also the previously mentioned reliability of the early engines almost insured there was work done on the engine any give trip off the beach.
So we'll need to look back at the reasons for the first few arrangements but we'll do that next post.
Cheers,
Kevin Morin
Kenai, AK
