Neel's Palm Beach 22 build
Neel
That is pretty much how we flipped the Bartender. :)
Post by neel thompson »
Jimmy,,,, The way I am going to finish the hull starts at the waterline. I will stain the sides from the waterline to the sheer. Then seal the stain and apply about seven coats of varnish. Then I will put the boat in the water after motor, fuel, etc. has been installed to mark the exact waterline. Then I will adjust the bottom paint to the new water line. Then the boot stripe at the top edge of the waterline gets painted. Then seven to 10 more coats of varnish over the stained sides. No epoxy, no clearcoat.... Neel.
Ibrew2be
Post by Ibrew2be »
Greetings Neel.
Could you please say more about why you don't use epoxy when finishing above the water line?
Thanks.
Barry
Barry Shantz
Imp built and launched.
Slowly building Ken Bassett's Rascal
Greetings to you Barry,,, I don't use epoxy above the WL because I like the look of varnish (with amber tint) over stain. I certainly don't like working with epoxy either. Many others have, but I was never able to get a great finish on anything that was epoxy coated. So I have stuck with what I know, and it's that simple. Are you thinking about going to the Gathering in September? Take care,, Neel
Neel, are you brushing varnish on a project that big? or spraying?
I used foam brushes on my Gentry, but thinking about rolling and tipping on this one
When I redid the Zip, I rolled with RedTree rollers and no tipping with Epifanes thinned about 10%. I initially long boarded between coats slightly with (I think) 400 just to keep things level. Later coats were just scuffed with Scotch Brite using a 6" RO air sander. 17 coats in all and the finish was BEAUTIFUL.
I used filler stains, Petit sealer, and Epifanes.
Ibrew2be
Post by Ibrew2be »
Thanks for the perspective Neel.
Rosemary and I are still undecided about the Gathering this year. We likely won't decide until we get closer to the date, and would plan to stay in a nearby hotel.
Barry
Barry Shantz
Still waiting for my strut so I can drill the shaft hole. So I have been getting ready to flip. The forward roll thing has been installed and braced in all directions. I can't install the aft one until the shaft hole has been drilled. I also put on three coats of bottom paint on the forward half and two coats on the aft half. The third coat will go on the aft section after the hole has been drilled. I also made a swim platform along with support braces, but that will probably be the last thing I put on the finished boat.
denbrlr
Post by denbrlr »
Neel,
Looks good. I know you are itching to flip her over :) and waiting for a part is painful.
Lee
Impressive contraption for flipping .
Ga-Steve
Post by Ga-Steve »
Very nice, Sir! Good luck with the strut. Are they having trouble with the shipping? We’ve had two non boat items delayed several times. Steve
As far as I know, it hasn't been shipped yet. Just hoping shipping delays will not an issue...
I got news from Glen-L that my strut won't be shipped until 6/16. So I decided to install the rest of the "roll cage" and get everything braced and ready to flip.. The prop shaft hole will be drilled through the hull slightly aft of the rear roll thing. When the strut comes, I will drill the hole, touch up the bottom paint and hopefully get it right-side-up before the end of June. I will have to put a temporary hold on the boat build after that as we are going to Florida from 7/7 to 8/7. Here are some pictures of my flipping contraption
DaveM
Post by DaveM »
Mr Thompson - I used a similar setup on a 23 tahoe using 3/4 plywood and 2 X4's. The flip went smoothly with 3 people, but the catch is not lifting it up its when you get over center letting the hull down, or controlling the rate of fall. I used a small block and tackle attached high on the opposite wall to the direction of turn.
