Mixed Epoxy 4:1 instead of 5:1
nkalson
Post by nkalson »
What are problems associated with mixing epoxy a little too hot? Mixed up an encapsulation batch for raw plywood, rolled it on then realized that I got the ratio wrong.
NK
Re: Mixed Epoxy 4:1 instead of 5:1
Not a good idea to change epoxy mixing ratio. That said, I bet the batch you mixed wrong still got hard and will perform well.
NK
I don't see it as a real problem. It definitely will go off. Encapsulation is not for strength. Most of hardener is solvent that evaporates. So, the ratio isn't that far off.
nkalson
Post by nkalson »
Thanks for the response.
Update - seems to have gone off just like a correctly mixed batch on lower deck. I'm a newbie and freak out when I do something wrong.
NK
Return to “Epoxy”
