Fisherman
epiziali
Re: Fisherman
Post by epiziali »
This is what sheer will look like when I clamp tight
Eric
Re: Fisherman
Looks money to me.
283
Re: Fisherman
Post by 283 »
epiziali wrote:
Thu Mar 14, 2019 6:30 pm
Pic of gap
Hard to say from looking at pics. But I think a shim added to fill that gap is a good idea...if it isn’t it’s easy to to plane it back off.
...Looking good.
Mike
Re: Fisherman
Take a step back and get a long look at the chine and the sheer. Sight down them from several angles. If they have a smooth curve, and twist, without humps or dips, its time for a happy dance. :D :D :D Tom
Re: Fisherman
Post by DrBryanJ »
From the pic it looks like you could use a shim, but sight down the side to see what you have. For some reason, looking with your head upside down actually helps see the deformities more easily.
epiziali
Re: Fisherman
Post by epiziali »
First I'm gonna shim, then I'm gonna dance, might even do the shimmy. Thanks guys!
Eric
epiziali
Re: Fisherman
Post by epiziali »
Finding okoume in northern cal is proving difficult. I found a local supplier with marine grade meranti 1088. Anyone have experience with meranti?
Eric
Re: Fisherman
epi
My Bartender is all Meranti. It is a little heavier. You may need to plan your exposed cut so the blade enters on the "good" side. It tends to splinter. It's good though. It is supposed to be a little more rot resistant.
Re: Fisherman
I'm using Meranti. It splinters and is a little stiffer than Meranti. Tom
Otter
Re: Fisherman
Post by Otter »
+1 on the splintering.
I'm also using meranti, mostly because I like the color and grain better than Okoume. and it is cheaper
I badly splintered a few of the frame gussets (no big deal in those, will be a bigger deal when I get to planking) but eventually figured out a couple of days to minimize the splintering.
1. as suggested in earlier post, make sure entry side of saw tooth is on "good" side of plywood
2. use finer tooth blade
3. place masking tape over saw line prior to sawing
Doing all three of those has helped decrease my splintering significantly.
Chris Otterness
Building a Ski-Bass
Re: Fisherman
Post by PeterG »
Sounds like you have the meranti figured out! I used meranti for all of my flat pieces like transom, motorboard, gussets, stem, etc. I found your cutting methods most helpful. One other suggestion I got from this forum is to use a razor or utility knife to precut the face ply prior to sawing it, it prevents splintering too.
epiziali
Re: Fisherman
Post by epiziali »
Thanks for feedback on Meranti. I found some Okuame in So. Cal and freight is not too bad. I am going to go with it. Let you know how it works out for me.
Eric
epiziali
Re: Fisherman
Post by epiziali »
I am down to fine tuning on fairing. Feels good to get through this part. I am going to write down my notes and lessons learned. Maybe someone will come along and benefit from these. If I am off based on your experience, feel free to chime in and provide better guidance as I am no expert after fairing a single boat.
1. When you get really stuck, ask the forum!
2. Before you start taking off material, make a plan for where you are trying to go. Use straight edge or scrap material to help guide you. I found shading in areas to be removed with pencil very useful.
3. Its a slow process. Don't try to go fast. I learned to to take 4-6 passes, and then check my angle and depth. Work small sections. Depending on section, that might only be 8"-12" at a time. I think this helped prevent mistakes (I still made mistakes, but you can recover by adding or subtracting material).
4. If you cannot tell how much material is coming off or if you are at the right angle. Stop. Use your straight edge or scraps to help you figure it out.
5. Small scraps are helpful; I also bought full sheets of cheep underlayment that I found super helpful. Particularly when you get past last frame and work toward the stem.
6. I used 5 tools for fairing. I think each works better/best on different parts of the boat.
Rasp: getting started in certain areas like frames to chine line; stem to chine.
Hand Planer: Chines, this was most fun part for me! Battens.
Power planer: Keel, Sheer clamp, and battens
Belt sander: Keel, stem.
Block planer; here and there. Not much.
And you can never have too many clamps!
Eric
epiziali
Re: Fisherman
Post by epiziali »
tools
Eric
Re: Fisherman
Go to the box store and buy a long, thin piece of molding, as long as you can get home. it will give you a good line across many frames.
epiziali Good list.
