Approximating Displacement for Canoes and Kayaks
Posted by Glen Witt on Jan 23rd 2018
Glen-L Can-Yak built by Bruce Kiley.
A common question is "how much weight will she hold?" This especially applies to smaller boats such as canoes or kayaks.
The following will give a rough idea of the displacement of a typical double ended craft such as a kayak or canoe. It will not be accurate with boats that have a transom.
The factors required can usually be measured from the boat or possibly the lines or sections. All measurements must be in feet. These are:
- D = draft . Estimate draft at the widest point of the boat or approximate midpoint; usually about 3" - 6" on the typical canoe / kayak.
 - B = maximum beam at bottom. If round bottom measure width about 3" above keel.
 - L = waterline length or length chine point to chine point fore and aft measured along the centerline of the boat.
 - Disp. = displacement, weight of everything on board plus boat weight.
To find the displacement at the estimated waterline use the following formula.
.6D x B x L x 62 = Displacement in pounds, fresh water.
Let's take an example:
We have a kayak that has a draft of 6" (.5'), a midships bottom width of 20" (*1.67'), and a waterline length of 17'. Putting these figures in the formula:
.6 x .5 x 1.67 x 17 x 62 = 528 lbs. fresh water displacement.
But let's say we know the total weight to be carried, boat weight, passengers and gear, in other words displacement: but how far will the boat sink in the water? Suppose we have a displacement of 450 lbs. Using the kayak example above the formula is altered to solve for draft.
Displacement ------------------ = Draft (D) .6 x B x L x 62
OR
450 ----------------------- = .43' or 5 1/8" draft .6 x 1.67 x 17 x 62
Are the formulas accurate? No, but close enough for estimates. Basically it calculates the underwater volume and converts with a factor (.6) derived from a group of kayaks whose characteristics had been calculated.
Be practical when you consider load carrying ability. Many people, however, are not. They want a small kayak that will carry two full blown adults with lots of gear. Don't expect to load the boat so there are only a couple of inches of freeboard. Some even want to carry several passengers in a 12' kayak. Use a string to simulate the boat outline on the living room floor. Sit the passengers contemplated in the outline and you will readily see if what you desire is practical.
* Convert inches to feet by dividing by 12.
