Boatbuilder Tip: Using the Versatile Block Plane
Posted by John Brantuk on Mar 19th 2014
Roundovers
Edges are simple to shape with the block plane. For chamfers less than 1/8" you can usually eyeball the cut as you move the plane along the edge of the board. For wider chamfers, first draw a layout line on the workpiece as a guide.
Flush Trimming
There are several ways to trim hardwood edging on plywood, but a block plane can be one of the quickest. As you trim, just skew the plane toward the edge of the panel. This way, you’ll minimize the risk of gouging the face of the plywood. Then just make several passes along the edging.
End Grain Trimming
It's a good idea to purposely cut dovetails or box joint fingers a little long so you can trim them perfectly flush after assembly. Just make light passes across the ends of the fingers until the joints are flush. Be sure to cut into your workpiece (not away) to prevent splitting the edges.
Smoothing
Cleaning up an edge with a block plane is a lot faster and more efficient than getting out sandpaper. You can remove saw marks, burn marks, and mill marks with just a few passes, as shown in the left photo.
