Glen-L 12 Fiberglass Kit
71-116A
$460.00
Fiberglass covering for the bottom, sides, and transom.
Fiberglass kit includes:
5 yds 38" cloth
4 yds 60" cloth
2-1/4 Gallons Raka Epoxy with slow hardener
application instructions
Glen-L Epoxy Fiberglass Covering will need to be either painted or varnished to protect the epoxy from UV rays. This resin can be used for a bright wood finish, although a waxy film (amine blush) may occur on the surface between coats that will have to be wiped off with solvent.
