Glen-L 14 Hardware and Rigging Kits
GH-118
$579.00 - $649.00
Standard Kit for Wood Mast & boom includes: Rudder gudgeons and pintles, rudder stop, gooseneck, jam cleats, mast tangs, chainplates with covers, masthead sheave with pin, eye straps, bow plate, jib halyard block, mainsheet blocks, swivel eyeblocks on deck plate, adjustable jib sheet slides on track with stops, centerboard sheave, and centerboard pulley.
Deluxe Kit for Wood Mast & boom includes: Rudder gudgeons and pintles, rudder stop, gooseneck, jam cleats, mast tangs, chainplates with covers, masthead sheave with pin, eye straps, bow plate, jib halyard block, mainsheet blocks, swivel eyeblocks on deck plate, centerboard sheave, centerboard pulley, quick action jib sheet cam cleats on tracks with stops, plus a mainsheet cam cleat with block for ease in handling the mainsheet.
Rigging Kit: Includes all stainless steel shrouds and forestay with swaged fittings and forestay turnbuckle, shroud adjusters, all halyards, and all sheets of yacht braid line. Rigging ready for installation.
Spar Fittings includes all of the fittings for an ALUMINUM mast: masthead fitting with sheaves, hound fitting, mast tangs, gooseneck, end cap, jib halyard block with fittings, and all required jam cleats. All parts ready for assembly,with instructions.
NOTE: The mast is not included in this kit but can be purchased from Dwyer Mast--their DM4 mast is compatible with these spar fittings. The boom is made from wood as detailed in the plans.
Note #2: For complete rigging of this boat, you'll also need to order a Hardware kit for Alum Spar (either standard or deluxe) and the Rigging Kit.
Deluxe Hardware Kit for Aluminum Spars (use when also ordering the spar fittings kit) includes: Rudder gudgeons and pintles, rudder stop, jam cleats, mast tangs, chainplates with covers, eye straps, bow plate, jib halyard block, mainsheet blocks, swivel eye blocks on deck plate, centerboard sheave, centerboard pulley, quick action jib sheet cam cleats on tracks with stops, plus a mainsheet cam cleat with block for ease in handling the mainsheet.
