Use for Glen-L 25 and 25 Duet Fiberglass covering for the bottom, sides, and transom.
Fiberglass kit includes:
41 yds 50" cloth
9-3/4 Gallons Raka Epoxy with slow hardener
application instructions
Glen-L Epoxy Fiberglass Covering will need to be either painted or varnished to protect the epoxy from UV rays. This resin can be used for a bright wood finish, although a waxy film (amine blush) may occur on the surface between coats that will have to be wiped off with solvent.
Glen-L 25 Fiberglass Kit
            $930.00
