The following is a list of dimensions which can be used to determine if the camper you are interested in will fit you truck WITHOUT modification to the plans and patterns. If the dimensions of your truck vary from those given, minor modifications can usually be made, especially with regard to the lower portion or "box" of the camper. While making a camper larger or smaller in width, length, or height will usually not be a problem, adjustments will need to be made to aluminum sizes shown on the plans.
| CAMPER DESIGN | 'A' | 'B' | 'C' | 'D' | 'E' | 'F' |
| ACAPULCO | N/C | 49" | 65" | 19 3/4" | 25' | 46" |
| BAYOU | N/C | 49" | 49" | 19 3/4" | N/C | 46" |
| CASCADE | 8'6" | 49" | 65" | 19 3/4" | N/C | 46" |
| DIXIE | 8'6" | 49" | 49" | 19 3/4" | N/C | 46" |
| EVERGLADE | 8'6" | 49" | 65" | 19 3/4" | N/C | 46" |
| FAIRHAVEN | 8'6" | 49" | 65" | 19 3/4" | N/C | 46" |
| GRANDVIEW | 8'6" | 49" | 65" | 19 3/4" | N/C | 46" |
| IMPORTER | 6'4 1/4" | 38 1/4" | 42" | 16 3/8" | N/C | 37" |
| IMPORTER LONG BED | 8'0" | 38 1/4" | 55" | 16 3/8" | N/C | 37" |
'A' = Maximum distance in truck bed which will limit forward travel of camper. |
| COVER DESIGN | 'A' | 'B' | ![]() |
| HUSKY (All) | 78" | 105" | |
| OUTBACK | 62" | 77" | |
| OUTBACK LONG BED | 62" | 93" |
'A'= Maximum width (*)
'B' = Maximum length at truck side (*)
(*)NOTE: These dimensions can be varied if desired, however, if increased, the aluminum skin sizes will need to be adjusted.
