These cast brass packing gland stuffing boxes are the most common type used. The flax packing around the shaft is held in place by the threaded gland cap, locked with a jam nut. Can be replaced in position, without removing the tiller arm. In emergency the packing can be temporarily replaced with string or strips of T-shirt.
Flange size: 3-7/8" square
Length below base: 4",
Bolthole center to center: 2-3/4"
Bolt size: 3/8" Bolt holes: 1/4", hole ctr to hole ctr: 2 5/16"
Packing size: 1/4"
1" Brass Rudder Port Stuffing Box
$299.00
