Amp Eater Stitch & Glue Kit A
74-511A
$330.00
Use this kit if you intend on fiberglassing the exterior--you'll need to also order the Fiberglass kit at some point. Includes material for assembling the hull.
3 gallons Raka epoxy with slow hardener
1 lb microspheres
1 lb silica
8 yd 38" cloth
50 feet copper wire
6 dz 3/4" #8 bronze screws
5 dz 1" #8 bronze screws
1 gross 1 1/2" #8 bronze screws
2 ea 3" #14 bronze screws
1/2 lb 3/4" #14 bronze ring type nails
1/2 lb 1" #12 bronze ring type nails
1 ea 3/8"x6" galvanized carriage bolt, with nut & washer
