Designer's Notebook: Altering Arrangement Plans
Posted by Glen Witt on Mar 29th 2012
One of the many fun parts of building your own boat is to make changes to fit your own needs, particularly on your boat’s cabin floor plan. In most cases, unless a major weight is shifted, such changes are quite doable. One caveat to this, however; you may not have the space that you think you have…a boat, unlike a house, doesn’t have that nice flat floor, plus the “walls” are sloping, realities which limit the usable area. Thus, don’t just look at the floor plans but check the sections to find out how much usable space is actually available.
The best way to make changes in arrangements is to first have fun making all the changes you’d ultimately desire on the drawings. Before seriously committing to a revised layout, however, wait until the hull is right side up. Only then can the full scope of the area be viewed. Now you should mock up your new layout, using sticks of wood, cardboard, etc. Then see if the alterations can be accomplished and figure out where you can make little compartments to stash whatever.
When making changes questions will arise as to how big is a berth, what is comfortable seating height, and so forth. Obviously you can check a chair or measure an existing item, but there are a few sizes and measurements not set in stone but generally accepted in terms of comfort and usability. Some of these items and their measurements are as follows in alphabetical order:
Berth 6’2” x 2'2” (min.)
Cabinet Worktop Depth 24”
Cabinet Worktop Height 33”
Companionway 24”+ wide but if very short on space 21” is minimum
Doorways 24” wide but 21” adequate if seldom used
Eye Height Sitting 38”
Eye Height Standing 69”
Hatch Openings 14” x 18” (min.) but 18” x 18” is preferable
Helm 11” from bottom of steering wheel to seat cushion
Helm 25” from center of steering wheel to backrest
Seat Depth 16”-18”
Seat Height 18”
Seat Slope 5 to 7 degrees fore to aft
Sitting Headroom 35”
Table Size (for 4 people) 39” x 30”
Toilet Room (Head) 27” x 27” x 51” height (minimum)
