Clear Coat Laminating Epoxy
S3-CLEARCT
$44.95 - $359.95
Clear Coat is an extremely low viscosity, water white, "penetrating" epoxy system. Clear Coat cures to a brilliantly clear, very tough finish without the usual "amine blush" associated with some epoxy resin films. Clear Coat contains no volatile solvents.
Turbo Cure may be added speed up cures during cold weather. Use a maximum of 1 fluid ounce per quart of resin. A two part epoxy coating and laminating resin for use in marine and woodworking applications. Use as a sealer, topcoat, saturation coat or tie-coat.
• Features a convenient 2:1 mixing ratio.
• A clear, almost water-white, solvent-free epoxy system.
• Cures to a clear, glossy, blush-free surface.
Product Uses:
Clear Coat is ideal for clear coating wood, and the wetting out of fiberglass cloth for bright finished boats. Use as a build coat for clear linear polyurethane or varnish coatings and as a penetrating first coat for blister repair on fiberglass boats. Use also for those applications that require a long pot life and low viscosity. Use Clear Coat as the sole epoxy system to make wood strip canoes and kayaks. Protect Clear Coat from moisture during cure to avoid water spotting.
Please choose size from drop-down above.
Cannot be shipped outside the US as this is a hazardous product.
