Glen-L 15 Hardware and Rigging Kits
GH-119
$598.00
Standard Kit for Wood Mast & boom includes: Rudder gudgeons and pintles, rudder stop, gooseneck, jam cleats, mast tangs, chainplates with covers, masthead sheave with pin, eye straps, bow plate, jib halyard block, mainsheet blocks, swivel eye blocks on deck plate, adjustable jib sheet slides on track with stops, centerboard sheave, and centerboard block.
Deluxe Kit for Wood Mast & boom includes: Rudder gudgeons and pintles, rudder stop, gooseneck, jam cleats, mast tangs, chainplates with covers, masthead sheave with pin, eye straps, bow plate, jib halyard block, mainsheet blocks, swivel eyeblocks on deck plate, centerboard sheave, centerboard block, quick action jib sheet cam cleats on tracks with stops, plus a mainsheet cam cleat with block for ease in handling the mainsheet.
Spar Fittings Kit: Includes a masthead fitting with sheaves, hound fitting, mast tangs, diamond stays with fittings, spreaders and spreader fitting, gooseneck, end cap, jib halyard block with fittings, and all required jam cleats. All parts ready for assembly, with instructions.
These parts will fit a DM4 Mast extrusion from DwyerMast.com
Deluxe Hardware Kit (use when also ordering the spar fittings kit) includes: Rudder gudgeons and pintles, rudder stop, jam cleats, mast tangs, chainplates with covers, masthead sheave with pin, eye straps, bow plate, jib halyard block, mainsheet blocks, swivel eye blocks on deck plate, centerboard sheave, centerboard block, quick action jib sheet cam cleats on tracks with stops, plus a mainsheet cam cleat with block for ease in handling the mainsheet.
Rigging Kit: Includes all stainless steel shrouds and forestay with swaged fittings and forestay turnbuckle, shroud adjusters, all halyards, and all sheets of yacht braid line. Rigging ready for installation.
