La Paz Fiberglass Kit
71-033PA
$910.00
Fiberglass covering for the bottom, sides, and transom.
Fiberglass kit includes:
16 2/3 yds 38" cloth
16 2/3 yds 50" cloth
6-3/4 Gallons Raka Epoxy & Slow Hardener
application instructions
Glen-L Epoxy Fiberglass Covering will need to be either painted or varnished to protect the epoxy from UV rays. This resin can be used for a bright wood finish, although a waxy film (amine blush) may occur on the surface between coats that will have to be wiped off with solvent.
