These luxury-sized fifth wheel trailers are perfect for extended traveling. The large balcony bedrooms feature full size twin or double beds. All facilities can be included for extended self-containment. Bathrooms can be fitted with either tub or shower, and storage areas are commodious. Just about any conventional pick-up truck of suitable capacity can be used for towing. By using our detailed plans, you can build your own fifth wheel trailer, all at a cost far less than factory built units.
Fifth wheel trailers are the ultimate in travel trailer living. They feature spacious balcony sleeping areas and extended interior length. Yet, overall length is much less than a car-trailer combination of similar area. Handling, maneuverability, and stability are superior because the fifth wheel hitch is located over the pick-up truck axle. GLEN L plans cover all aspects of building your own fifth wheel trailer so even an amateur can achieve that "factory-made look". Only GLEN-L provides comprehensive construction manuals as well as full size patterns of contoured sidewall areas to make building easier, results more professional.
- Trailer length overall:
 - 29'6"
 - Trailer width overall:
 - 7'10"
 - Interior length overall:
 - 29'1"
 - Interior width overall:
 - 7'6"
 - Interior height (headroom):
 - 6'5"
 - Balcony area height (inside):
 - 54"
 - Dry weight (estimated):
 - 6000 lbs.
 - Hitch weight (estimated):
 - 1500 lbs.
 - Ground to roof height:
 - 9'7"
 - Fresh water capacity:
 - 30 min./60 max. gallons
 - Holding tank capacity:
 - LPG capacity:
 - 10 min./14 max. gallons
 - Sleeping capacity:
 - 6 adults
 - Ground to frame clearance:
 - 13"
