Useful Measures, Tables, & Formulas
5-1-01: In response to a builder request we have added this page. Let us know if you have any suggestions for additional weights or measurements we should add.
- One cubic foot of volume will support approx. 60 lbs.
- One cubic foot of fresh water weighs 62.5 lbs.
- One cubic foot of salt water weighs 64 lbs.
- One gallon of gasoline weighs 6.2 lbs.
- One gallon of Diesel fuel weighs 7.1 lbs.
- One cubic foot of volume contains 7.48 gallons.
- One board foot - A lumber measurement. One board foot = 1" X 12" X 12". A piece of lumber 2" X 12" X 12" = 2 board feet. When width and thickness are specified, lumber may be called out as linear feet, i.e. 1" X 6" X 24 linear feet. Linear feet is used when the the lumber will be cut into various lengths, as opposed to a piece 1" X 6" x 24' which would be a single piece of wood.
To use this chart:
From X Multiplier = Into
Into X Reciprocal = From
| From Into | Multiplier | Reciprocal | |
| Inches | Millimeters | 25.4 | 0.0394 |
| Length | |||
| 1/8ths of inches | Millimeters | 3.175 | 0.315 |
| 1/16ths of inches | Millimeters | 1.587 | 0.630 |
| Inches | Meters | 0.0254 | 39.37 |
| Feet | Meters | .3048 | 3.281 |
| Yards | Meters | .914 | 1.094 |
| Miles | Kilometers | 1.609 | 0.621 |
| Sea Miles | Meters | 1852 | 0.000539 |
| Miles | Meters | 1609.3 | 0.000621 |
| Area | |||
| Square inches | Square centimeters | 6.4516 | 0.155 |
| Square feet | Square meters | 0.0929 | 10.764 |
| Volume | |||
| Cubic inches | Cubic centermeters | 16.387 | 0.061 |
| Cubic inches | Liters | 0.016 | 62.5 |
| Cubic feet | Cubic meters | 0.028 | 35.315 |
| Cubic yards | Cubic meters | 0.765 | 1.308 |
| Imperial gallons | Liters | 4.546 | 0.220 |
| USA gallons | Liters | 3.785 | 0.264 |
| Imperial gallons | USA gallons | 1.205 | 0.830 |
| Weight | |||
| Grams | Ounces | 0.035 | 28.35 |
| Pounds (lbs.) | Kilograms | 0.454 | 2.205 |
| Hundredweights (cwt) | Kilograms | 50.802 | 0.020 |
| Tons | French tonnes | 1.016 | 0.984 |
| Density | |||
| Pounds per cubic foot | Kilograms per cubic meter | 16.019 | 0.0624 |
| Speed | |||
| Kilometers per hour | Meters per second | 0.278 | 3.6 |
| Meters per second | Knots | 1.943 | -- |
| Feet per second | Meters per second | 0.305 | 3.281 |
| Feet per second | Miles per hour | 0.682 | 1.467 |
| Feet per minute | Kilometers per hour | 0.018 | 54.68 |
| Miles per hour | Meters per second | 0.447 | 2.237 |
| Miles per hour | Kilometers per hour | 1.609 | 0.621 |
| Knots | Miles per hour | 1.151 | -- |
| Horsepower (hp) | kilowatts (kW) | 0.746 | 1.341 |
Basic Mathematical Formulas
Distance
1 foot = 12 inches
1 yard = 3 feet
1 mile = 5,280 feet
1 mile ≈ 1.61 kilometers
1 inch = 2.54 centimeters
1 foot = 0.3048 meters
1 meter = 1,000 millimeters
1 meter = 100 centimeters
1 kilometer = 1,000 meters
1 kilometer ≈ 0.62 miles
Area
1 square foot = 144 square inches
1 square yard = 9 square feet
1 acre = 43,560 square feet
Volume
1 cup = 8 fluid ounces
1 quart = 4 cups
1 gallon = 4 quarts
1 gallon = 231 cubic inches
1 liter ≈ 0.264 gallons
1 cubic foot = 1,728 cubic inches
1 cubic yard = 27 cubic feet
1 board foot = 1 inch by 12 inches by 12 inches
Weight
1 ounce ≈ 28.350 grams
1 pound = 16 ounces
1 pound ≈ 453.592 grams
1 milligram = 0.001 grams
1 kilogram = 1,000 grams
1 kilogram ≈ 2.2 pounds
1 ton = 2,000 pounds
Rectangle
perimeter = 2(length + width)
area = length x width
Rectangular Solid (Box)
volume = length x width x height
Cube
volume = (length of side)3
Triangle
sum of angles = 180°
area = ½ (base x height)
Circle
number of degrees in a circle = 360°
circumference ≈ 3.14 x diameter
area ≈ 3.14 x (radius)2
Cylinder
volume ≈ 3.14 x (radius)2 x height
Cone
volume ≈ ![]()
Sphere (Ball)
volume ≈ 4/3 x 3.14 x (radius)3
Electricity
1 kilowatt-hour = 1,000 watt-hours
amps = watts ÷ volts
Temperature
°C = 0.56(°F – 32) or 5/9(°F – 32)
°F = 1.8(°C) + 32 or ( 9/5 x °C) + 32
Table: Inches to Millimeters
| 1/8 | 3.2 |
| 1/4 | 6.4 |
| 3/8 | 9.5 |
| 1/2 | 12.7 |
| 5/8 | 15.9 |
| 3/4 | 19.1 |
| 7/8 | 22.2 |
| 1 | 25.4 |
| 2 | 50.8 |
| 3 | 76.2 |
| 4 | 101.6 |
| 5 | 127.0 |
| 6 | 152.4 |
| 7 | 177.8 |
| 8 | 203.2 |
| 9 | 228.6 |
| 10 | 254.0 |
| 11 | 279.4 |
| 12 | 304.8 |
Table: Feet to Meters
| Feet | Meters & Millimeters |
| 1 | .305 |
| 2 | .610 |
| 3 | .914 |
| 4 | 1.219 |
| 5 | 1.524 |
| 6 | 1.829 |
| 7 | 2.134 |
| 8 | 2.438 |
| 9 | 2.743 |
| 10 | 3.048 |
Table: Pounds to kilograms
To use this chart:
The numbers down the left side are even number of pounds. To find the kilogram equivalent of 22 pounds, go to the "20" row and look in the "2" column.
| Pounds | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 |
| 0 | -- | 0.45 | 0.91 | 1.36 | 1.81 | 2.27 | 2.72 | 3.18 | 3.63 | 4.08 |
| 20 | 9.07 | 9.53 | 9.98 | 10.43 | 10.89 | 11.34 | 11.79 | 12.25 | 12.70 | 13.15 |
| 40 | 18.14 | 18.60 | 19.05 | 19.50 | 19.96 | 20.41 | 20.87 | 21.32 | 21.77 | 22.23 |
| 60 | 27.22 | 27.67 | 28.12 | 28.58 | 29.03 | 29.48 | 29.94 | 30.39 | 30.84 | 31.30 |
| 80 | 36.29 | 36.74 | 37.19 | 37.65 | 38.10 | 38.56 | 39.01 | 39.46 | 39.92 | 40.37 |
| 100 | 45.36 | 45.81 | 46.27 | 46.72 | 47.17 | 47.63 | 48.08 | 48.53 | 48.99 | 49.44 |
| 120 | 54.43 | 54.88 | 55.34 | 55.79 | 56.25 | 56.70 | 57.15 | 57.61 | 58.06 | 58.51 |
| 140 | 63.50 | 63.96 | 64.41 | 64.86 | 65.32 | 65.77 | 66.22 | 66.68 | 67.13 | 67.59 |
| 160 | 72.57 | 73.03 | 73.48 | 73.94 | 74.39 | 74.84 | 75.30 | 75.75 | 76.20 | 76.66 |
| 180 | 81.65 | 82.10 | 82.55 | 83.01 | 83.46 | 83.91 | 84.37 | 84.82 | 85.28 | 85.73 |
| 200 | 90.72 | 91.17 | 91.63 | 92.08 | 92.53 | 92.99 | 93.44 | 93.89 | 94.35 | 94.80 |
| 220 | 99.79 | 100.24 | 100.70 | 101.15 | 101.61 | 102.06 | 102.51 | 102.97 | 103.42 | 103.87 |
| 240 | 108.86 | 109.32 | 109.77 | 110.22 | 110.68 | 111.13 | 111.58 | 112.04 | 112.49 | 112.95 |
| 260 | 117.93 | 118.39 | 118.84 | 119.30 | 119.75 | 120.20 | 120.66 | 121.11 | 121.56 | 122.02 |
| 280 | 127.01 | 127.46 | 127.91 | 128.37 | 128.82 | 129.27 | 129.73 | 130.18 | 130.64 | 131.09 |
| 300 | 136.08 | 136.53 | 136.99 | 137.44 | 137.89 | 138.35 | 138.80 | 139.25 | 139.71 | 140.16 |
| 320 | 145.15 | 145.60 | 146.06 | 146.51 | 146.96 | 147.42 | 147.87 | 148.33 | 148.78 | 149.23 |
| 340 | 154.22 | 154.48 | 155.13 | 155.58 | 156.04 | 156.49 | 156.94 | 157.40 | 157.85 | 158.30 |
| 360 | 163.29 | 163.75 | 164.20 | 164.65 | 165.11 | 165.56 | 166.02 | 166.47 | 166.92 | 167.38 |
| 380 | 172.37 | 172.82 | 173.27 | 173.73 | 174.18 | 174.63 | 175.09 | 175.54 | 175.99 | 176.45 |
| 400 | 181.44 | 181.89 | 183.34 | 182.80 | 183.25 | 183.71 | 184.16 | 184.61 | 185.07 | 185.52 |
| 420 | 190.51 | 190.96 | 191.42 | 191.87 | 192.32 | 192.78 | 193.23 | 193.68 | 194.14 | 194.59 |
| 440 | 199.58 | 200.03 | 200.49 | 200.94 | 201.40 | 201.85 | 202.30 | 202.76 | 203.21 | 203.66 |
| 460 | 208.65 | 209.11 | 209.56 | 210.01 | 210.47 | 210.92 | 211.37 | 211.83 | 212.28 | 212.74 |
| 480 | 217.72 | 218.18 | 218.63 | 219.09 | 219.54 | 219.99 | 220.45 | 220.90 | 221.35 | 221.81 |
| 500 | 226.80 | -- | -- | -- | -- | -- | -- | -- | -- | -- |
Table: Square feet to square meters
| 10 | 0.93 |
| 20 | 1.86 |
| 30 | 2.79 |
| 40 | 3.72 |
| 50 | 4.65 |
| 60 | 5.57 |
| 70 | 6.50 |
| 80 | 7.43 |
| 90 | 8.36 |
| 100 | 9.29 |
| 110 | 10.22 |
| 120 | 11.15 |
| 140 | 13.01 |
| 160 | 14.86 |
| 180 | 16.72 |
| 200 | 18.58 |
| 220 | 20.44 |
| 240 | 22.30 |
| 260 | 24.15 |
| 280 | 26.01 |
| 300 | 27.87 |
| 320 | 29.73 |
| 340 | 31.59 |
| 360 | 33.45 |
| 380 | 35.30 |
| 400 | 37.16 |
| 420 | 39.02 |
| 440 | 40.88 |
| 460 | 42.74 |
| 480 | 44.59 |
| 500 | 46.45 |
Table: Speed Conversions, Knots, MPH, KPH
| SPEED CONVERSIONS - KNOTS, MPH, KPH | ||
| Knots | Miles per Hour | Kilometers per Hour |
| 1 | 1.152 | 1.85 |
| 2 | 2.303 | 3.70 |
| 3 | 3.445 | 5.55 |
| 4 | 4.606 | 7.41 |
| 5 | 5.758 | 9.26 |
| 6 | 6.909 | 11.13 |
| 7 | 8.061 | 12.98 |
| 8 | 9.212 | 14.83 |
| 9 | 10.364 | 16.68 |
| 10 | 11.515 | 18.55 |
Table: Millimeter equivalents of screw and nail gauges specified in Glen-L plans [inches (decimal) X 25.4 = mm]
| Gauge No. | Screw Diameter | Nail Diameter | ||
| inches | mm | inches | mm | |
| 8 | .163 | 4.1 | - | - |
| 10 | .189 | 4.8 | .134 | 3.4 |
| 12 | .216 | 5.5 | .109 | 2.8 |
| 14 | .242 | 6.2 | .083 | 2.1 |
| 18 | .294 | 7.5 | - | - |
Table: Pipe ID and OD
| Nominal ID Sched. 40 | OD inches |
| 1/4" | .540 |
| 3/8" | .675 |
| 1/2" | .840 |
| 3/4" | 1.050 |
| 1" | 1.315 |
| 1 1/4" | 1.660 |
Table: Metal gauges
| Gauge No. | Thickness | |
| mm | inches | |
| 6 | 4.87 | 0.192 |
| 7 | 4.46 | 0.176 |
| 8 | 4.06 | 0.160 |
| 9 | 3.66 | 0.144 |
| 10 | 3.25 | 0.128 |
| 11 | 2.94 | 0.116 |
| 12 | 2.64 | 0.104 |
| 13 | 2.34 | 0.092 |
| 14 | 2.00 | 0.080 |
| 15 | 1.83 | 0.072 |
| 16 | 1.62 | 0.064 |
| 17 | 1.42 | 0.056 |
| 18 | 1.22 | 0.048 |
Table: Fahrenheit/Centigrade
| Conversion formulas: oC = oF - 32 divided by 1.8, oF = oC X 1.8 + 32 |
| oC | oF |
| 0 | 32 |
| 1 | 33.8 |
| 2 | 35.6 |
| 3 | 37.4 |
| 4 | 39.2 |
| 5 | 41.0 |
| 6 | 42.8 |
| 7 | 44.6 |
| 8 | 46.4 |
| 9 | 48.2 |
| 10 | 50.0 |
| 11 | 51.8 |
| 12 | 53.6 |
| 13 | 55.4 |
| 14 | 57.2 |
| 15 | 59.0 |
| 16 | 60.8 |
| 17 | 62.6 |
| 18 | 64.4 |
| 19 | 66.2 |
| 20 | 68.0 |
| 21 | 69.8 |
| 22 | 71.6 |
| 23 | 73.4 |
| 24 | 75.2 |
| 25 | 77.0 |
| 26 | 78.8 |
| 27 | 80.6 |
| 28 | 82.4 |
| 29 | 84.2 |
| 30 | 86.0 |
| 31 | 87.8 |
| 32 | 89.6 |
| 33 | 91.4 |
