Alpha 2 Hardware and Rigging Kits
GH-100
$294.16 - $730.00
Standard Hardware Kit for use with a Wood Mast & boom
Standard Kit includes: Rudder gudgeons and pintles, rudder stop, gooseneck, jam cleats, mast tangs, centerboard pin, centerboard pulley, chainplates, masthead sheave with pin, eye straps, bow plate, tiller pulleys, all eyebolts, jib sheet blocks, jib halyard block, mainsheet deck block, mainsheet blocks, and mainsheet base block.
Deluxe Kit for Wood Mast includes: Rudder gudgeons and pintles, rudder stop, gooseneck, jam cleats, mast tangs, centerboard pin, centerboard pulley, chainplates, masthead sheave with pin, eye straps, bow plate, tiller pulleys, all eye bolts, jib sheet blocks, jib halyard block, mainsheet deck block, mainsheet blocks, plus jib sheet cam cleats and mainsheet cam cleat with block for ease in handling the mainsheet.
Standard Hardware Kit for Aluminum spars includes: Rudder gudgeons and pintles, rudder stop, jam cleats, mast tangs, centerboard pin, centerboard pulley, chainplates, eye straps, bow plate, tiller pulleys, all eyebolts, jib sheet blocks, jib halyard block, mainsheet deck block, mainsheet blocks, and mainsheet base block, plus jib sheet cam cleats and mainsheet cam cleat with block for ease in handling the mainsheet.
Deluxe Hardware Kit for Aluminum spars includes: Rudder gudgeons and pintles, rudder stop, jam cleats, mast tangs, centerboard pin, centerboard pulley, chainplates, eye straps, bow plate, tiller pulleys, all eye bolts, jib sheet blocks, jib halyard block, mainsheet deck block, mainsheet blocks, plus jib sheet cam cleats and mainsheet cam cleat with block for ease in handling the mainsheet.
Rigging Kit: Includes all stainless steel wire rope shrouds and forestay and turnbuckle with swaged fittings and forestay turnbuckle, shroud adjusters, and halyards, sheets, and centerboard pennant of yacht braid line. Rigging ready for installation.
