Minuet Hardware and Rigging Kits
GH-129
$107.00 - $1,150.00
Hardware Kit for Wood Mast includes: Rudder gudgeons and pintles, rudder stop, gooseneck, jam cleats, bobstay eye, jib tack eye, chainplates, mast tangs, masthead sheave with pin, eye straps, jib halyard block, mainsheet blocks, swivel eye blocks on deck plate, adjustable jib sheet slides on track with stops, cam cleats, cheek blocks, mainsheet cam cleat with block for ease in handling the mainsheet, and centerboard pulleys. (Note that we no longer include the Eye Band aka Cranse Iron in this kit)
Spar Firrings Kit: Includes a masthead fitting with sheaves, hound fitting, mast tangs, gooseneck, end cap, jib halyard block with fittings, and all required jam cleats and eye straps. All parts ready for assembly, with instructions.
The aluminum mast can be purchased from Dwyer Mast. The Minuet requires an 18 foot DM4 and can be ordered at their website:
Hardware Kit (use when also purchasing the Spar Fittings Kit for the aluminum mast from Dwyer Mast Co.) includes: Rudder gudgeons and pintles, rudder stop, bobstay eye, jib tack eye, chainplates, jam cleats, eye straps, jib halyard block, mainsheet blocks, swivel eye blocks on deck plate, adjustable jib sheet slides on track with stops, cam cleats, cheek blocks, mainsheet cam cleat with block for ease in handling the mainsheet, and centerboard pulleys. (Note that we no longer include the Bowsprit Eye Band aka Cranse Iron in this kit)
Rigging Kit: Includes all stainless steel wire rope shrouds, forestay,whisker stays, and bobstay, swaged fittings, shroud and forestay adjusters, and turnbuckles swaged to whisker stays, and lower shrouds, plus all halyards, and sheets of yacht braid line. Rigging ready for installation.
