Aqua-Lube Strut Bearing
90-282P
$27.50
Aqua-Lube bearings are made of micarta and are water lubricated with continuous longitudinal grooves to provide adequate water lubrication for the shaft to prevent excessive wear and friction. Cut in half and inserted into either end of the strut bearing housings. Order for any strut with the proper I.D and O.D.
