Glen-L 10 Mast Hardware and rigging kits
GH-114
$90.00 - $285.20
Hardware Kits for Wood masts
Glen-L 10 Hardware Kit for Wood Mast-Standard
Standard Hardware Kit for Wood Mast & Boom includes: Rudder gudgeons and pintles, rudder stop, gooseneck, jam cleats, mast tangs, traveler block, bullet blocks with eyestraps, chainplates with covers, masthead sheave with pin, eye straps, bow plate, and swivel eye block on plate.
Glen-L 10 Hardware Kit for Wood Mast-Standard with KU fitting
Standard Hardware Kit for Wood Mast & Boom includes: Kick-Up Rudder fitting, gooseneck, jam cleats, mast tangs, traveler block, bullet blocks with eyestraps, chainplates with covers, masthead sheave with pin, eye straps, bow plate, and swivel eye block on plate.
Glen-L 10 Hardware Kit for Wood Mast-Deluxe
Deluxe Hardware Kit for Wood Mast & boom includes: Rudder gudgeons and pintles, rudder stop, gooseneck, jam cleats, mast tangs, traveler block, bullet blocks with eye straps, chainplates with covers, masthead sheave with pin, eye straps, bowplate, and pivoting cam cleat for a hands free mainsheet.
Glen-L 10 Hardware Kit for Wood Mast-Deluxe with KU Fitting
Deluxe Hardware Kit for Wood Mast & boom includes: Kick-Up Rudder fitting, gooseneck, jam cleats, mast tangs, traveler block, bullet blocks with eye straps, chainplates with covers, masthead sheave with pin, eye straps, bowplate, and pivoting cam cleat for a hands free mainsheet.
Hardware kits for Aluminum masts
Glen-L 10 Aluminum Spar Fittings Kit
Spar Kit: Includes fittings for use with a Dwyer Mast #DM4 (dwyermast.com) aluminum mast, masthead fitting with sheaves, hound fitting, mast tangs, gooseneck, end cap, and jam cleats. All parts ready for assembly, with instructions. Shipping weight 8 lbs.
Note: This kit does not contain the mast or boom. The boom is made of wood and detailed the plans, the mast can be purchased fromDwyer Mast. You'll need their DM4 in 20' length.
Glen-L 10 Hardware Kit for Alum Spar-Standard
Standard Hardware Kit (use when also purchasing Spar Fittings Kit) includes: Rudder gudgeons and pintles, rudder stop, jam cleats, mast tangs, traveler block, bullet blocks with eye straps, chainplates with covers, eye straps, bow plate, and swivel eye block on plate.
Glen-L 10 Hardware Kit for Alum Spar-Standard with KU Fitting
Standard Hardware Kit (use when also purchasing Spar Fittings Kit) includes: Kick-Up Rudder fitting, jam cleats, mast tangs, traveler block, bullet blocks with eye straps, chainplates with covers, eye straps, bow plate, and swivel eye block on plate.
Glen-L 10 Hardware Kit- for Alum Spar-Deluxe
Deluxe Hardware Kit (use if also ordering the Aluminum Spar Fittings Kit) includes: Rudder gudgeons and pintles, rudder stop, jam cleats, traveler block, bullet blocks with eye straps, chainplates with covers, eye straps, bow plate, and a pivoting cam cleat for a hands free mainsheet.
Glen-L 10 Hardware Kit- for Alum Spar-Deluxe with KU Fitting
Glen-L Rigging kit
Rigging Kit: Includes all stainless steel shrouds and forestay with swaged fittings and forestay turnbuckle, shroud adjusters, all halyards, and all sheets of yacht braid line. Rigging ready for installation.
