Blackfish Bearing
90-352
$80.95
Code: Blackfish Shaft Size: 1" O.D. of Bearing: 1 1/4" Bearing Length: 4"
These marine bearings meet the toughest kinds of marine service, whether for pleasure boat or workboat use. The fluted rubber liner yields to any abrasive particles which may work between the shaft and the bearing, and the open grooved design allows the lubricating water to wash out these particles. This same rubber lining compensates within the bearing for shaft deflection and shock, while at the same time assuring smooth vibration-free shaft operation, and long shaft and bearing life. Because they protect against shaft scoring and last longer than other bearings, they are more economical over the long run.
