Electrical Design - Shorepower for Cabin or Open Boats up to 23 feet PDF
EL-211-S
$35.00
Outboard/Inboard/IO - Shorepower only: This system is circuit breaker based and contains the wiring for a system that is useful for multiple day cruising with a complete equipment package for open or cuddy cabin boats up to 23 feet LOA.
