Electrical Design - DC and Shorepower for Cabin Boats up to 23 feet PDF
EL-211-DCS
$85.00
Outboard/Inboard/IO - DC and Shorepower: This system is circuit breaker based and contains the wiring for a system that is useful for multiple day cruising with a complete equipment package for cuddy cabin boats up to 23 feet LOA.
