Outboard/Inboard/IO - DC only: This system is circuit breaker based and contains the wiring for a system that is useful for multiple day cruising with a complete equipment package for cuddy cabin boats up to 30 feet LOA.
All plans are sent electronically in PDF format for instant download after ordering. The link to the PDF will be provided in the confirmation email sent right after you place your order. If you don't get it right away, please email us.
Electrical Design - DC only for Cabin Boats 23 to 30 feet PDF
$80.00
