Electrical Design - DC only for Open Boats 23 to 30 feet PDF
EL-300-DC
$80.00
Outboard/Inboard/IO - DC only: This system is circuit breaker based and contains the wiring for a system that is useful for multiple day cruising with a complete equipment package for open boats up to 23 feet LOA.
