Shaft Log 12º Bronze
GL-CL12
$149.00
Shaft logs are available in varying angularities to match your installation. When connected to the stuffing box with a rubber hose, the angle can vary 1-2 degrees from that noted. A stuffing box to suit, stainless clamps, and a hose are required to complete a shaft log assembly.
Base Size: 3 1/2" x 12"
Angle: 12 degrees
The unit measures 13 1/2" L x 3 5/8" W x 2 1/2" D overall. The blade is approximately 5/16" thick. There are (10) 1/4" dia. holes on the blade. The sleeve is 1 1/2" long with a 1 5/8" OD and 1 3/8" inside diameter. Commonly used by Malibu Boats.
