Shaft Log - 15 Degree Bronze
90-195
$114.00
Shaft logs are available in varying angularities to match your installation. When connected to the stuffing box with a rubber hose, the angle can vary 1-2 degrees from that noted. A stuffing box to suit, stainless clamps, and a hose are required to complete a shaft log assembly.
Base Size: 3 5/8" x 8 1/2"
Angle: 15 degrees
Hose: 1-5/8" & 1-3/4" ID
Predrilled with 5 holes each side of base
Made of red bronze, manufactured by Marine Hardware
